New to Toyota, 4-high issue.... - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 2nd Generation (1990-1995)
2nd Generation (1990-1995) Discussion area for the second generation Toyota 4Runner.
Old 01-01-2011, 08:35 PM   #1 (permalink)
View Tstory's Photo Gallery
I have a few questions. I have just purchased my first Toyota it is a 1992 4 runner with a 5speed 4 banger. So far I have figured out its gremlins except for the 4 wheel drive system. when i engage the 4 high or low the front tires do not spin, the drive shaft turns but not the wheels. When I rotate the wheels by hand the half shafts turn. What am I missing. I noticed a electrical conection on the pumpkin and also some vacum lines what are those for. so far besides this issues all is good. Any help.
Tstory is offline   Reply With Quote
Old 01-02-2011, 12:46 AM   #2 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3639050
to the nation! I'll move your thread over to the 4Runner forums so the members there can help you out.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is online now   Reply With Quote
Old 01-02-2011, 03:51 AM   #3 (permalink)
Gameroom cash: $425365
View jetwhine's Photo Gallery
Tstory,
First off the vacuum lines are for engaging the auto locker, switching on and off the drive motor to engage and disengage the front wheels. The electrical connection is for the light on the gauge cluster to tell you that the 4wd system has been activated.
So now some questions. Does the green or blue light come on to tell you that you have engaged the fwd system? The next question is. Have you checked for leaks in those 2 vacuum lines. They tend to get damaged and will leak. If thy leak it will either not engage or not disengage.
jetwhine is offline   Reply With Quote
Old 01-02-2011, 11:10 AM   #4 (permalink)
jetwhine,
Thanks for your information, I took the dash apart to discover that 60% of the light bulbs have been removed. Today I am going to install new ones and then I can answer your question. Stay tuned Awsome response thanks again.
Old 01-02-2011, 11:38 AM   #5 (permalink)
View 99blackSE's Photo Gallery
Try swapping the lines at the brown and blue modules (VSVs) that the vac lines run to. Takes 5 seconds and could save you a lot of time.
1991 4Runner SR5 - 22R-E - G58 - daily/mild trails
1984 Pickup SR5 - 22R - ??? - work to do
Goners: '91 V6 4R SR5 x2, '93 V6 4R SR5, '84 4R SR5
99blackSE is offline   Reply With Quote
Old 01-02-2011, 08:36 PM   #6 (permalink)
out on bail
fourwd1's Avatar
Gameroom cash: $593155
View fourwd1's Photo Gallery
Originally Posted by jetwhine View Post
Tstory,
Just to be clear, the vacuum lines are not engaging a locker, a locker is a traction adding device installed in the differential.
The vacuum lines are for the actuator used to connect the two parts of the driver's side half shaft. This is the heart of Toyota's Automatic Disconnecting Differential (ADD) 4WD system. It is located adjacent to the diff on the drivers side of the axle housing.
ADD 101 and 102
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
Old 01-03-2011, 05:52 AM   #7 (permalink)
Yes thats what I ment. The ADD thats the ticket. Sorry a brain fart on the nomenclature. I knew what I was thinking but it came out wrong.
