Originally Posted by impendingdoom229
How necessary is it to replace the knock sensor and do you have any guess as to how much it would cost?
When the computer sees no signal / proper signal ( backround noise) from the knock sensor , it goes into failsafe mode and retards your timing to the max value, causing poor performance and gas milage.
Normally when your engine is knocking the ECM will retard your timing to prevent engine damage, but you will not get a trouble light. The light comes on when the ECM is not getting ANY or normal backround signal.
Like Tech 1984 said, its usually the pigtail on the 3.0 V6 and it is alot of work to get to. If you have a shop do it, it will be expensive.
Some people have had luck installing a new sensor onto the engine lift hook and bypassing the old one.
This has worked for some ,but you loose the protection of your knock sensor, since it is not in the proper place to detect knocking anymore.
