randomly wont start anymore - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 2nd Generation (1990-1995)
2nd Generation (1990-1995) Discussion area for the second generation Toyota 4Runner.
Old 01-18-2011, 07:20 PM   #1 (permalink)
View 4runner93's Photo Gallery
alright so ive looking through all these posts and i cant seem to find any that will help me yesterday out of random my 93 POS 3.0L wont start let alone even turn so i jumped the neutral safety switch nothing. i tested my starter. that works it has a brand new batter i know its not that i have no idea whats going on and i'm really getting frustrated with it any help would be amazing thanks
4runner93 is offline   Reply With Quote
Old 01-19-2011, 12:45 AM   #2 (permalink)
Gameroom cash: $425365
View jetwhine's Photo Gallery
4runner93,
I would check out to see if you have any fuses blown. Then I would suspect a bad key switch.
jetwhine is offline   Reply With Quote
Old 01-19-2011, 06:44 PM   #3 (permalink)
i checked my fuses and nothing and then i tried wiggling the key around to see if that would work but nothing
Old 01-20-2011, 05:50 AM   #4 (permalink)
4runner93,
How did you check your starter? And if you think the starter is ok then maybe you have a bad starter relay. The relay is located in the No.1 junction box on the drivers side. Maybe pull it out and make sure the connection does not have any corrosion on it. You can test it by removing it and applying battery voltage to terminals 1&2 then check for continuity at terminals 3&5. If out of spec. then replace it.
Old 01-20-2011, 02:21 PM   #5 (permalink)
i jumped the terminals on the solenoid and it starts right up and i swaped out the relay and it still didnt work
Old 01-20-2011, 11:29 PM   #6 (permalink)
4runner93,
Key switch???
Old 01-21-2011, 03:43 PM   #7 (permalink)
well i ended up figuring it out. i found an old alarm system in it that decided to break and set off its kill switch i didnt even know i had an alarm system so i just bypassed it. but thanks for all the help
Old 01-22-2011, 02:51 AM   #8 (permalink)
4runner93,
Man I hate those alarm systems.
