Originally Posted by jetwhine
Toypick,
Well I have a few thoughts.
1) Has your rig been tampered with as far as the fuel tank is concerend. In other words is your tank stock?
2) The up hill and acceleration issue sounds like the pump is cavatatiing when the fuel moves to the back of the tank when low.
3) When it reads 1/4 tank how far can you go before you run out?
4)) Also in the tank there is a holding pit around the fuel pump to keep that type of problem from happening. So maybe that has come loose and the fuel moves to the back of the tank and causes fuel pump cavitation on a low fuel level.
I saw this PIT in the middle of the tank as you speak of, and I Was actually wondering what it was for.
The pump SEEMS TO HAVE BEEN CHANGED because there was some weird fiberglass around it which appeared to me as a redneck gasket.
IF I'M NOT MISTAKENED IN MY HYPOTHESIS, I would believe that the fuel pump should be SITTING in this PIT, and right now as we speak it seems as the filter hangs a littler HIGHER so would the pump assembly be replaced with something that is not exactly stock?
