1991 3.0 time for a valve job? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 2nd Generation (1990-1995)
2nd Generation (1990-1995) Discussion area for the second generation Toyota 4Runner.
Old 03-03-2011, 08:36 PM   #1 (permalink)
Registered User
View bigrod00's Photo Gallery
I have a rough idle and bad gas mileage on a 5 speed 3.0. I have checked for vacuum leaks cleaned air filter, PVC valve good. I am not getting any check engine light. I am suspecting a valve issue??? I recently purchased this unit for quite cheap. The previous owner had a compression check and he had lower #6 compression. It had 329,000 kms on it. It does not smoke or steam, overheat and drives better at higher rpm. Oil is good color and antifreeze stays full. Am I in for a head job or can it be something simple? Any help would be greatly appreciated. I have also tried adjusting timing and idle. Intake manifold appears to fine and no vacuum leaks. I reset computer and rough idle still there. Intake from air cleaner to fuel injection good. It has a new timing belt job by Toyota very recently.
bigrod00 is offline   Reply With Quote
Old 03-04-2011, 04:25 PM   #2 (permalink)
Gameroom cash: $425365
View jetwhine's Photo Gallery
bigrod00,
With that many miles it might be time to clean the throttle body. It might also be a sticking EGR valve.
jetwhine is offline   Reply With Quote
Old 03-04-2011, 06:06 PM   #3 (permalink)
Registered User
Originally Posted by jetwhine View Post
bigrod00,
What would you suggest cleaning it with? Romove intake and spray down with cleaner or can I do it on truck?
Old 03-06-2011, 12:03 AM   #4 (permalink)
bigrod00,
I would take it off to clean it. You can do a much better job if it is off. Also while you have it off you should check the TPS throttle position sensor idle setting. It is done with a feeler gauge. I would use Isopropel alchahol it works great and leaves no residue and is cheap to purchase.
Old 03-08-2011, 09:55 AM   #5 (permalink)
View ZARTT's Photo Gallery
2nd Generation Valve Job??
How low was the compression in #6?
The reason I ask is because #6 is the cylinder where the head gasket usually fails if it is going to, on a 3VZE engine.
The exhaust from the odd cylinder side of the motor crosses over the bell housing through a pipe, and meets the exhaust from the even side of the motor right in the area of #6.
The driver side rear cylinder (#6) has the heat from all 6 cylinders concentrated in that corner of the motor.
You might want to investigate that possibility.
Art.
ZARTT is offline   Reply With Quote
Old 03-08-2011, 04:47 PM   #6 (permalink)
Registered User
Thumbs down
Art.
#6 valves not sealing. I will be replacing heads on weekend when gasket set arrives.
