antena replace - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 2nd Generation (1990-1995)
2nd Generation (1990-1995) Discussion area for the second generation Toyota 4Runner.
Old 03-28-2011, 03:25 PM   #1 (permalink)
View Bills86e's Photo Gallery
antena replace
1994 4-runner SR5, 3.0, 4WD.
Problem is the RADIO ANTENA
Its broke off, and whines for 60 seconds at engine start-up or shut off.
Do I need to take off fender and take out dash to replace it? Or easy alternative?
Bills86e is offline   Reply With Quote
Old 03-29-2011, 11:08 AM   #2 (permalink)
View Astralplane's Photo Gallery
http://antennamastsrus.com/Toyota/4%...01990-1995.htm
Astralplane is offline   Reply With Quote
Old 03-29-2011, 11:27 AM   #3 (permalink)
Thats great infomation on what to do "After I remove the Antenna from the car".
How to just do that tho?
Old 03-29-2011, 12:44 PM   #4 (permalink)
http://antennamastsrus.com/Toyota/4%...ner%20Mast.htm
Read step 5
You will need to remove the wheel well liner to gain access the antenna assembly.
Old 03-29-2011, 01:11 PM   #5 (permalink)
Excellent! THANK YOU!
Old 04-04-2011, 03:17 PM   #6 (permalink)
Yes!!! It was very simple, but was easy with you guys help. The gear cable came
loose from the old mast and I pulled WW liner, and electrical motor assembly, pulled old cable out, then replaced it, the new mast with geared cable fed right in!!! A+
It took 23 minutes.
