'95 4Runner Engine sudden stop problems.
I have a 1995 4Runner in West Africa, It is 4wd, v6, manual transmission, It started the problem of suddenly shuting down the engine while in motion 2 months ago, the car will just go off (turn off) while in motion.
Several other times if I start the car and drive for some minutes and switched off the engine, The 4Runner engine will not startup again until after several minutes of manually touching and checking all fuse before it will start again.
I have took the 4Runner to several Engine mechanics and electrical wiring mechanics with no solution because of lack of diagnostic tools in the area.
Can anyone please help with suggestion on possible solution areas for the mechanics to check to resolve this problem or what part could be responsible for this problem.
Thanks in advance.
