ground problem - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 2nd Generation (1990-1995)
2nd Generation (1990-1995) Discussion area for the second generation Toyota 4Runner.
Old 04-21-2011, 02:45 PM   #1 (permalink)
View goldfinder30's Photo Gallery
USA ground problem
I can only get my 95 to run if I ground to the green wire on the open circuit relay, or jumper wire in the test port. What do I need to do?
goldfinder30 is offline   Reply With Quote
Old 04-21-2011, 05:51 PM   #2 (permalink)
out on bail
fourwd1's Avatar
Gameroom cash: $593155
View fourwd1's Photo Gallery
Both those actions bypass the fuel pump inter-lock switch located in the AFM, supplying power to the fuel pump.
So most likely the problem is in the AFM.
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
The Following User Says Thank You to fourwd1 For This Useful Post:
goldfinder30 (04-21-2011)
