concern about my build - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 2nd Generation (1990-1995)
2nd Generation (1990-1995) Discussion area for the second generation Toyota 4Runner.
Old 04-22-2011, 06:11 PM   #1 (permalink)
View snaplakemucker's Photo Gallery
Canada concern about my build
hey boys...im continuing on my 95 4runner build for the bush toy im planning on comin up with..a little while ago i posted a forum on frame repair......the 4runner i got from a friend ....well he nosed it hard on the front right...then rolled...ect..ect..well i got a free 88 pickup today from the friends son.....it has a 4cylinder fuel injected engine...and it is one of those extra cab trucks.....it has rear leaf instead of coils like my 4runner....my question is can i tranfer everything from my 4runner to this pick up frame......or is the pickup not as tough or heavy duty like the 4runner....the diffs......or will even the 4runner body fit on the pick up frame...i like this idea cause then i have a solid straight frame to work with......there is no box left on the pickup and the cab is done.....i want to keep the 4runner body cause i just built it into a minin avalanche type style......any way can some one point me in the right direction ....thanks guys...happy wheeling....
snaplakemucker is offline   Reply With Quote
Old 04-22-2011, 09:19 PM   #2 (permalink)
out on bail
fourwd1's Avatar
Gameroom cash: $593155
View fourwd1's Photo Gallery
I did a little comparing of some 88 frame dimensions to some 93 frame dimensions in the FSM's, and a lot of the body mounting points are close. The only way to tell for sure is to get under both trucks and measure all the mounting points and compare them. There are going to be differences because you are dealing with 2 different generations and p/u vs 4Runner. You are bound to have to make some modifications.
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
Old 04-23-2011, 08:37 AM   #3 (permalink)
Canada right on....
That sounds good....im a ticketed welder so doing some mods shouldnt be a problem....my other question is.. is there any difference between the axles..[diffs]im going to transfer my 3.0 liter drive train to the truck frame and will this work with the smaller 22r diff's.?..or can it be done swapping out the diffs from the 4runner to the pickup frame.....the 4runner has coil springs on the rear axle...the pickup has leafs on its frame....any help would be great....thanks for your time...
Old 04-23-2011, 12:54 PM   #4 (permalink)
out on bail
fourwd1's Avatar
The V6 rear diff is a bit beefier than the 4 cyl diff. The 4cyl is pretty strong tho, swapping them is up to you.
The axle housing will accept either one.
As for the suspension, you could keep the leaf spring setup or swap the 4Runner axle and coil suspension parts over. You'd have to fab some mounts or buy them at the dealer.
89 4Runner - stock
Old 04-23-2011, 02:44 PM   #5 (permalink)
right on...im only running 31x10.50x15 BFG's mudterrain on the front and 31x12.50x15 swamper boggers on the rear.well this looks good to start going ahead with my build.....thanks for all your time and answers...take care
