94 no power to starter or fuel pump - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 2nd Generation (1990-1995)
2nd Generation (1990-1995) Discussion area for the second generation Toyota 4Runner.
Old 04-23-2011, 01:05 AM   #1 (permalink)
View alex1972's Photo Gallery
I bought a 94 that hit a deer on passenger side front it has been sitting for over a year I dont have power to the starter but i do have power coming out of switch so I ran a wire from there and it turns over wont start. I have no power to fuel pump if i ether it it will start but wont stay running any help thanks Alex
alex1972 is offline   Reply With Quote
Old 04-23-2011, 02:02 AM   #2 (permalink)
Gameroom cash: $425365
View jetwhine's Photo Gallery
alex1972,
Try jumping the B+ and FP sockets in the diagnostic box just behind the fuse box in the engine compartment on the passenger side of engine on the wheel well and try and start the rig. This will bypass the circuit opening relay and the switch in the AFM.
jetwhine is offline   Reply With Quote
Old 04-23-2011, 01:25 PM   #3 (permalink)
Originally Posted by jetwhine View Post
alex1972,
Ive got power to starter now but still no fuel pump coming on. There was some kind of after market theft system hooked to the starter wire just bypassed it and it turns over thanks for the help Alex
Old 05-06-2011, 11:53 PM   #4 (permalink)
View jimmy996's Photo Gallery
Hi,
I'm having a similar problem, though I have no aftermarket theft system installed.
turning the key to on, does not power up the fuel pump,
jumpering the B+ and FP works, the pump runs,
I've tried starting the truck with the Fuel pump jumpered, however the truck will not turn over.
it acts as though no fuel is getting to the cylinders.
where do i start looking?
what tests can I do to find out what's wrong?
thanks
Jimmy
jimmy996 is offline   Reply With Quote
Old 05-07-2011, 12:32 AM   #5 (permalink)
jimmy996
OK with this scenario you might have a bad circuit opening relay or a bad vafm (volume air flow meter) switch. You can try to jump the FC wire at the vafm to ground and see if the fuel pump comes on with key on. If it does then you will have to fix the vafm or change it. If it does not come on then you have a bad circuit opening relay. It can be fixed if you can determine wiitch capacitor is bad.
I would also disconnect the fuel line forward of the fuel filter and see if you are getting fuel out of the fuel filter. IF not then disconnect the line behind the fuel filter and see if you get fuel. But you need to determine if the pump is actually pumping fuel when running. That would be the first coarse of action.
Old 05-09-2011, 11:49 PM   #6 (permalink)
thanks! ill test that when I go out to the truck next weekend.
