When shut down the engine.....the coolant start to boiling| - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 2nd Generation (1990-1995)
2nd Generation (1990-1995) Discussion area for the second generation Toyota 4Runner.
Old 05-01-2011, 06:52 PM   #1 (permalink)
View mimorepa's Photo Gallery
In my 1991 4Runner 22RE engine: I have the stated problem and the search of the solution procedure to start where the rule indicates ...... rectify the seat of the cylinder head, install the new gasket, check clucht fan .. . perfect, new water pump, new thermostat, radiator checked, hose, in perfect condition, no leaks, new radiator cap and ignition timing according to the manual ....... but when you shut the car, listening instant boiling coolant and pass into the reservoir.
In my review of various forum, I was referred to make the so-called t-block test: start the engine and the 30 seconds press or squeeze the upper hose (which runs from the thermostat to the radiator) and whether notes tense is an indication that there is a leak in the cylinder head to the cooling circuit.... in my case that hose under the pressure test do not observed this situation.
The temperature gauge indicates NORMAL OPERATING! and being seen on the engine, ALL related accessories and the cooling cycle are working according to the rule but something is wrong!.
I would like to thank any suggestions before proceeding to disassemble again to start the revision of the cylinder block or head for example to find internal cracks ........................ THANKS IN ADVANCE.
mimorepa is offline   Reply With Quote
Old 05-01-2011, 11:39 PM   #2 (permalink)
Gameroom cash: $425365
View jetwhine's Photo Gallery
mimorepa,
The reason it is boiling is that the system is not holding pressure. So you need to determine where the leak is. It could be as simple as a bad new radiator cap.
jetwhine is offline   Reply With Quote
Old 05-02-2011, 08:41 AM   #3 (permalink)
thanks .........I will check again!
