1995 4runner - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 2nd Generation (1990-1995)
2nd Generation (1990-1995) Discussion area for the second generation Toyota 4Runner.
Old 05-17-2011, 05:21 PM   #1 (permalink)
View laylad661's Photo Gallery
1995 4runner
I have a 1995 toy 4runner 3.0L auto and the engine was replaced with a rebuilt unit. Everything is now all put together and the vehicle will start and run for a few seconds before stalling out. The intake will fill with fuel. We disconnected the cold start fuel injector, but still filling up.
The cat. converter was stolen a few months ago, but that has nothing to do with it. Anyone have any tips?
laylad661 is offline   Reply With Quote
Old 05-18-2011, 12:43 AM   #2 (permalink)
Gameroom cash: $425365
View jetwhine's Photo Gallery
laylad661,
I'm thinking that you may have a problem with the fuel regulator. There is a vacuum line from the intake manifold that goes to the VSV (variable switching valve) that controls the fuel regulator. If the fuel pressure regulator is leaking internally and it is leaking in the vacuum portion of the regulator, the fuel will be sucked into the manifold at an uncontrolled rate. You can pull the vac line off of the VSV and see if fuel is coming out of it when the engine starts. That is the only way I can see that raw fuel can get into the manifold, other than the cold start injector.
jetwhine is offline   Reply With Quote
