A number of issues... - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 2nd Generation (1990-1995)
2nd Generation (1990-1995) Discussion area for the second generation Toyota 4Runner.
Old 06-15-2011, 09:24 AM   #1 (permalink)
View dhelsdon's Photo Gallery
Hey all,
So my 90' Runner has been acting up lately, I need some advice of a few things. First off and most notably, sometimes I am not able to shift gears. The clutch was replaced about 20,000 km ago and when I try to shift it's like there is no gear there.. no grinding or any strange sounds, just solid resistance. I have to release the clutch and re-engage it sometimes up to three times before it goes into gear. I read somewhere that it could be the clutch bracket, clutch adjustment (re-tighten) or something more serious.
My second woe is a very odd 'clacking' noise from the front right tire, it doesn't go away and it happens relative to my speed. It has been ongoing for a month or so as I haven't had time to look at any of these problems. At first I thought it might just be a piece of rock inside my drum or something but I figure it should've dislodged by now or broken into pieces.
The last and most minor issue is my emergency brake, it's super weak and I need to adjust it. I know this problem is an easy 10 minute fix, but I was wondering if anyone could tell me exactly where it's located to save me a bit of time.
For the record it's a 90' 22RE 5-spd manual.
Thank you
dhelsdon is offline   Reply With Quote
Old 07-02-2011, 10:34 PM   #2 (permalink)
out on bail
fourwd1's Avatar
Gameroom cash: $593155
View fourwd1's Photo Gallery
For the clutch, start with the basics. Have you checked the fluid level in the clutch MC?
For the front end noise, have you pulled the wheel off to check for problems?
For the parking brake, first make sure the rear shoes are adjusted properly, then there is an adjustment for the cable for the brake lever. It's underneath the truck, pass side.
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
