ignition timing off. - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 2nd Generation (1990-1995)
2nd Generation (1990-1995) Discussion area for the second generation Toyota 4Runner.
Old 07-04-2011, 04:55 PM   #1 (permalink)
View naterides's Photo Gallery
I just replacex the timing belt and distributor on my 3.0l V6 now the ignition timing is way off. It shouldbe at 10 degrees btdc at idle but only reaches that under a load. Its idling at 750 rpm and when I move the distributor it stalls. Can anyone help me?
naterides is offline   Reply With Quote
Old 07-05-2011, 02:06 AM   #2 (permalink)
Gameroom cash: $425365
View jetwhine's Photo Gallery
naterides,
Did you short the pins T1 and TE1 to check your timing? Other wise you won't get the right reading. And if you did, you might be off by one tooth on the timing belt, or you did not instal the distributor right.
jetwhine is offline   Reply With Quote
Old 07-05-2011, 02:17 AM   #3 (permalink)
I did short the 2 terminals, and I know the timing belt is bang on when I first got it back together it wouldn't start and I had to take it apart again. When I put the distributor in I set the engine at top dead center and positioned the rotor with the #1 connector on the cap, should it be offset from the # 1?
