oil pressure
Hi,
I have a 1990 4runner, v6, auto, 4wd, ps, pb, a/c, cruise, pw. 300+ thousand miles.
About a year ago the oil pressure gauge began to register lower than it did. It would register about 1/2 way across the gauge at higher rpms and close to the left side at idle. Then it began to stay almost to the left at idle and only 1/3 at higher rpms. I check the oil once a week anyway but now daily. Oil level always is at full mark. The truck doesn't leak or burn oil. I read somewhere about an external gauge that can measure pressure if attached somewhere right above the oil filter. The gauge costs around $45.
I want to fix this.
What should I do.
Thanks
