Hello All,
After replacing the top end of my 3.0. (The motor was replaced before I bought it). I started it and it has a miss to it. I also noticed that there is a lot of gas filling the muffler and coming out of the exhaust pipe. It takes about 7 min to stop leaking and the is only running it for a bout 3 minutes. Cant figure it out. Its gotta be something stupid. maybe wrong hose I put on some where. I don't know.
1.compression about 175 in all 6.
2.timing is good at all 3 marks , zero degree mark and both timing gears on the right and left head. up at the notch. Distributor / Rotor is pointing at #1 plug wire on cap.
3.new injectors all 6, plus new injector plugs 6 of them, solder, heat shrink, liquid electrical taped and then wrapped harness in electrical tape both sides.
At this time I've spent alot of money on parts. I don't have the cash to take it to toyota. Im getting no help from toyota service people at this time. They said "they have no idea bring it in". But at 92.50 hours who can afford that. That's like 4 time what I make an hour.
Have you never seen a grown man cry. Well I send pictures after getting the bill from Toyota if that's what I gotta do. If you all cant help me figure this out.
Thanks All,
Gary
