Ok guys, so here it is. 22re in a 92 pickup. I have rebuilt this truck from the ground up. swapped the motor for one with a new timing chain, installed fuel cell with high pressure inline pump, all new EVERYTHING, over ten grand invested. Everthing tests good, injector pulse, timing, valve clearance, fuel pressure, all right on. Spark at the plugs when I pull them out, but I do wonder if they may be breaking down under compression. The dizzy, wires, and plugs are all brand new, only thing I didnt replace is coil pack. Could a weak coil pack cause the plugs to break down, or is there another issue I have overlooked? Last summer I got it to pop with ether, but this year it wont even pop. Im ready to put a free sign on it
