oil dipstick and filler tube - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 2nd Generation (1990-1995)
2nd Generation (1990-1995) Discussion area for the second generation Toyota 4Runner.
Old 09-19-2011, 09:47 PM   #1 (permalink)
View jrunyan1229's Photo Gallery
I just bought a 1994 Toyota 4Runner. A couple of days later I went to check the oil and the filler tube fell off (I don't think it was ever secured). The dipstick showed way too much oil was in the engine when I pulled it out so I am wanting to drain it and change the oil as soon as possible. Does anyone know where the filler tube is located and how I should secure it on? I also need to know if you have the dimensions on it because I question if it is even the correct one. I have looked all around and don't see where it could fit. It is a V6 engine. Thanks.
jrunyan1229 is offline   Reply With Quote
Old 09-20-2011, 04:35 PM   #2 (permalink)
View cclvll4's Photo Gallery
Oil filler tube???????????
Your oil dipstick tube goes in the side of your block right below your motor mount. It isnt a filler tube though, you add oil through the drivers side valve cover. Your oil dip stick tube should have a bracket atached to it and it bolt to the front of the drivers side head. To help it stay in its block hole you need to replace the 10 cent " O " ring at the bottom of the tube
cclvll4 is offline   Reply With Quote
Old 09-21-2011, 09:50 PM   #3 (permalink)
Sorry, I meant dipstick tube, not filler tube. I have looked all over and I can't seem to find where the bracket can reach to bolt on anywhere.
Old 09-22-2011, 09:43 AM   #4 (permalink)
Dip stick
Here are some pics of mine, not real easy to see but the first one is my 88 Runner and the last 2 are my 95 Runner. in the last pic you can see the bracket going towards the front of the left head. I hope this helps even with it being so hard to see it will show you where they sit when bolted up. Good luck.
I tried to post the pics but cant fiure out how. If you send me an email adress I will send them to you
