90 4-runner in an out of overdrive.... - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 2nd Generation (1990-1995)
2nd Generation (1990-1995) Discussion area for the second generation Toyota 4Runner.
Old 09-21-2011, 02:51 PM   #1 (permalink)
View uraverageyota's Photo Gallery
so i'm trying to find this e-17 splice point......unable to find it been looking in the general area it is supposed to b located, unable to even find out which color coded wires they r. Anyone have some tips for me for locating. have looked behind the p/s pump and even have the intake plenium off still cant find it. Production date is 6/90
uraverageyota is offline   Reply With Quote
Old 09-21-2011, 06:21 PM   #2 (permalink)
out on bail
fourwd1's Avatar
Gameroom cash: $593155
View fourwd1's Photo Gallery
More info on what you're looking for would help. Where did you get e-17 from?
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
Old 09-21-2011, 09:26 PM   #3 (permalink)
e-17 splice point
exactly Ha! was trying to locate the e-17 splice point. Found a tsb for intermittent engagement of over drive, and the 4-runner i have is acting up a bit. So my toyota shop manual says to inspect splice point e-17. Was unable to find that exact splice point. Found the splices for the injectors but had no luck on locating this e-17 one.
Old 09-21-2011, 11:24 PM   #4 (permalink)
Gameroom cash: $425365
View jetwhine's Photo Gallery
uraverageyota,
That spiice is in the shroud that goes over the front of the engine over the top of the upper timing belt cover. If you are looking at the engine from the front it will be on the left hand side.
jetwhine is offline   Reply With Quote
Old 09-22-2011, 09:16 PM   #5 (permalink)
i hunted and hunted throughout that harness that snakes over the upper timing belt cover. Didn't find any other splice points exact for the 2 injector splices. Do u know off the top of ur head what color the ect should b....the sensor itself not the connector.
Old 09-23-2011, 12:27 AM   #6 (permalink)
uravarageyota,
The colors of the wires going to the ECT are: Green with blue stripe, and Brown with black stripe.
Hope this helps.
Old 09-23-2011, 04:41 AM   #7 (permalink)
thanks but do u know what the color should b of the coolant temp sensor itself.....I believe somebody may have installed the wrong one at one point.
