Fuel Economy – What is the most efficient speed?? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 2nd Generation (1990-1995)
2nd Generation (1990-1995) Discussion area for the second generation Toyota 4Runner.
Old 10-02-2011, 06:11 AM   #1 (permalink)
View Benn1e's Photo Gallery
Hi, i have a 2nd Gen 4Runner (1992) and im getting about 6km/s per 1Litre of petrol (about 16 miles per 1 Gallon). I don't drive it hard, but it does use a lot of gas
and I was wondiering,
1. if its possible to get better fuel economy?
2. what is the optimum speed/ most efficient speed on the highway?
Benn1e is offline   Reply With Quote
Old 10-02-2011, 07:59 PM   #2 (permalink)
out on bail
fourwd1's Avatar
Gameroom cash: $593155
View fourwd1's Photo Gallery
First, what engine do you have ?
Second, there are things you can do to help improve your mpg.
Basics like correct tire pressure, a complete tune-up, take it easy on the accel pedal, etc.
As for optimum speed for best mpg, you'll have to experiment to figure out what's best for your vehicle/conditions/etc.
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
Old 10-03-2011, 06:20 PM   #3 (permalink)
Exclamation MPG / KPL - fuel efficency - optimum cruising speed for v6 Engine
Hi fourwd1,
I have a SR5 3.0L V6 engine with Manual transmission. I run the tires on 32-34PSI (2.2Bar/ 220kpm - 2.3Bar/ 234kpm) and I'm not heavy on the gas. If experimented with regular and premium as well as premium while adding injector cleaner. Nothing seems to give me better mileage.
I had planned on giving it a full tune-up, however, before the previous owner sold it to me, they had it fully serviced for rego, and that was only about 6weeks ago! so it should be pretty spot-on!
With best mpg.. surely there must be an optimum cruising speed for the 4Runners? ie, i can understand how high winds, rain, or a heavy load would impede the results, but on a normal, cloud-free, no cargo/load day, I would imagine the best mpg would be achieved at around 90-100km/h? (56-62miles/hour) There must be an optimum cruising speed for the engine? - Does anyone else have info on this subject?
Let me know your thoughts fourwd1,
Thanks
Ben
Old 10-04-2011, 12:53 PM   #4 (permalink)
View JJGN's Photo Gallery
Ben,
I have 1992 4Runner 3.0 automatic and find that 60 mph at 2,500 rpms (in overdrive) with proper tune up and tires (31x10.5x15) correctly inflated gives me the best mileage. That is with regular gas (87 oct.). Windows, sunroof closed and no AC on. Once you put the AC on, you mpg drops off some.
JJGN is offline   Reply With Quote
Old 10-04-2011, 05:42 PM   #5 (permalink)
JJGN,
Thanks for the info. What MPG as a rough estimate are you getting?
Cheers
Ben
Old 10-16-2011, 08:14 PM   #6 (permalink)
View camry6's Photo Gallery
According to fuel ratings for the 3.0 4Runner of that generation, 16 MPG is about right. The 2.4L 22-RE 4 cylinder engine with the 5 speed manual is the most fuel efficient of all 4Runners. It gets an average of 20 MPG, which is what I get from mine.
1993 Toyota Camry V6 LE (200 HP, 195 ft/lbs tweaked) , 430,000 km's.
2002 Lexus GS 430 V8 VVT-i (300 HP, 325 ft/lbs) Luxury with Mark Levinson , 156,000 km's
2006 Lexus ES 330 V6 VVT-i (225 HP, 250 ft/lbs) Premium Luxury, Sport, Navigation with Mark Levinson , 140,000 km's
camry6 is offline   Reply With Quote
