Help with speedometer - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 2nd Generation (1990-1995)
2nd Generation (1990-1995) Discussion area for the second generation Toyota 4Runner.
Old 10-26-2011, 07:58 PM   #1 (permalink)
View deermike's Photo Gallery
I have a 1992 DLX pickup 4wd, 3.0, and 5 speed transmission.
Speedometer not working.
Have o volts to 12 volts pulsing from VSS. Have continuity on signal wire from VSS to combination meter. Have continuity from VSS to combination meter on the ground.
Tried two different combination meters from salvage yard.
Speedometer did not work with any.
Any way to bench test the speedometer?
Thanks
Mike
deermike is offline   Reply With Quote
Old 10-27-2011, 06:03 PM   #2 (permalink)
out on bail
fourwd1's Avatar
Gameroom cash: $593155
View fourwd1's Photo Gallery
I looked, can't find anything on checking the electronic speedo's meter. Just the sending unit, which you've already done.
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
