manually lowering rear window - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 2nd Generation (1990-1995)
2nd Generation (1990-1995) Discussion area for the second generation Toyota 4Runner.
Old 11-10-2011, 07:25 PM   #1 (permalink)
View chucke55's Photo Gallery
Hello there, my rear window motor is bad,and my turn signal went out. I'm trying to lower the window manually so I can open the door to get to my tailights. Any thoughts? thanks
chucke55 is offline   Reply With Quote
Old 11-10-2011, 10:45 PM   #2 (permalink)
Gameroom cash: $425365
View jetwhine's Photo Gallery
chucke55,
You may want to pull the panel off of the door from the inside to access the motor to disconnect it from the window to let it down. You may want to tape the window so it won't fall down while you disconnect it.
jetwhine is offline   Reply With Quote
Old 11-10-2011, 10:47 PM   #3 (permalink)
ALSO AVAILABLE IN SOBER
Zembonez's Avatar
Gameroom cash: $619331
View Zembonez's Photo Gallery
Might well be that the motor is good. I'd try pulling the interior panel from the inside enough to get to the wiring and jump it. Worth a shot.
Zembonez is offline   Reply With Quote
Old 11-11-2011, 07:58 PM   #4 (permalink)
Originally Posted by jetwhine View Post
chucke55,
The motor is bad so that is exactly what i'll have to do. Thank you very much
Old 11-11-2011, 08:01 PM   #5 (permalink)
Tried that already,will have to disconnect the motor.thank you very much anyway.
