Idle speed issues... - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 2nd Generation (1990-1995)
2nd Generation (1990-1995) Discussion area for the second generation Toyota 4Runner.
Old 11-17-2011, 10:30 PM   #1 (permalink)
Abedog91
View abedog91's Photo Gallery
So I have fixed most of the issues with my 95 4runner, now I am trying to adjust the idle speed. The idle speed now (in neutral, no accessories) is about 775. When its in Drive the idle speed drops to 500. This is with the engine at normal operating temps. What would cause this?
backing the adjustment screw out does not seem change the idle speed by very much.
...Also what should the idle speed be while in drive?
EDIT:
I forgot to add that the idle speed drops when the a/c is turned on and when the headlights are turned on as well.
abedog91 is offline   Reply With Quote
Old 11-17-2011, 11:54 PM   #2 (permalink)
Gameroom cash: $425365
View jetwhine's Photo Gallery
abedog91,
Need engine type info.
jetwhine is offline   Reply With Quote
Old 11-18-2011, 12:33 AM   #3 (permalink)
Abedog91
Originally Posted by jetwhine View Post
abedog91,
Thought it was in my sig. It is a 1995 Toyota 4Runner 2WD 3.0L EFI V6
Old 11-18-2011, 08:20 PM   #4 (permalink)
Abedog91
I got a trouble code coming up now, its code 25. Which says Air-fuel Ratio Lean Malfunction which Chilton says can deal with the Injector circuit, Injector, Fuel line pressure, Ignition system, Oxygen sensor circuit, Oxygen Sensor, Air Flow Meter, Water Temp. Sensor, and/or the ECU. Would any of this cause the roughness? Also the sound that is being made gets faster with the acceleration of the vehicle.
Old 11-19-2011, 01:19 AM   #5 (permalink)
abedog91,
The first thing I would check/change is the heated oxygen sensor.
Old 11-19-2011, 02:41 AM   #6 (permalink)
Abedog91
Yeah thats up there in like $90 to replace, I'll check it out. If you could think of anything else let me know... the idle speed has suddenly started to stay constant at about 775 in drive. So now I'm trying to find the reason for the trouble code and shakiness before trying to adjust idle anymore.
Old 11-20-2011, 02:10 AM   #7 (permalink)
abedog91,
I suggest fixing the check engine light first, and then perform trouble shooting if you are not satified with sthe results of fixing the CEL.
