OK to run 190F thermostat for winter - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 2nd Generation (1990-1995)
2nd Generation (1990-1995) Discussion area for the second generation Toyota 4Runner.
Old 12-17-2011, 01:43 AM   #1 (permalink)
View steellhead's Photo Gallery
Canada OK to run 190F thermostat for winter
replacing thermostat and wanted to know if hotter stat is alright for cold Canadian winters.
steellhead is offline   Reply With Quote
Old 12-17-2011, 04:12 AM   #2 (permalink)
Gameroom cash: $425365
View jetwhine's Photo Gallery
steellhead,
Does your rig take a long time to heat up? The temp indication should be just below half way on the kndicator defelction. If it is running cold and not coming up to temp then I would suggest putting a hotter one in otherwise don't fix it if it is not broken.
jetwhine is offline   Reply With Quote
Old 12-17-2011, 09:31 AM   #3 (permalink)
Canada
Originally Posted by jetwhine View Post
steellhead,
No, it heats up quick. The thermostat from PO is an 88C/190F kuzeh, is this the proper one or what?
Had to do a head gasket replacement and am wondering if this hotter stat is a possible cause of my blown gasket.
Old 12-17-2011, 07:39 PM   #4 (permalink)
out on bail
fourwd1's Avatar
Gameroom cash: $593155
View fourwd1's Photo Gallery
What engine do you have?
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
Old 12-18-2011, 06:47 AM   #5 (permalink)
steelhead,
IF you have the 22r-e the opening temp should be between 187-194 deg, and full open at 212 deg.
If you have the 3vz-e then it should start to open at 176-183 deg, and full open at 203 deg.
IF you should have any doughts about the type or condition then you should go to Toyota and buy the right one and all issues should be resolved.
The Following User Says Thank You to jetwhine For This Useful Post:
steellhead (12-20-2011)
Old 12-20-2011, 06:35 PM   #6 (permalink)
Originally Posted by fourwd1 View Post
what engine do you have?
3vze
Old 12-21-2011, 01:49 AM   #7 (permalink)
Steelhead,
With the 3vz-e history of overheating, I would not recomend a hotter thermostat.
