Clutch issue: Won't start with pedal to the floor - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 2nd Generation (1990-1995)
2nd Generation (1990-1995) Discussion area for the second generation Toyota 4Runner.
Old 12-29-2011, 07:01 PM   #1 (permalink)
Ca$h's Avatar
View Ca$h's Photo Gallery
The clutch pedal has been making a noise on the release for a few weeks. I didn't think anything of it, I figured it was the water on my shoes. Now it makes a slight pop on the press and a fainter noise on the release.
Yesterday I couldn't get her started in the morning with the clutch pressed to the floor. I had to use the clutch start cancel button to get her started. Later that day she started up fine. Now all today (four times) she would not start with the clutch to the floor. I had to use the clutch start cancel button to get her going.
Here is the weird part. There is no clutch fluid leaking. The clutch reservoir is still full. The car engages in gears quickly and easily. The clutch only has ~70k miles on it (the original went 190k). The pedal always comes right back up. No lag or lack of pressure.
Any ideas on the subject?
90 4runner v6 276,000 miles
Ca$h is offline   Reply With Quote
Old 12-29-2011, 07:30 PM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998175
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
Check/test the clutch start safety switch at the top of the clutch pedal.
The Jedi Speeder at CarDomain
Old 12-29-2011, 10:11 PM   #3 (permalink)
Ca$h's Avatar
Bingo! Thanks man.
So it turns out the pedal doesn't hit the switch when the pedal is pushed to the floor. For a temp fix I rubberanded a pad of duck tap so that the pedal pushes the switch in when fully pressed.
Getting the bar the switch is on to move seems like a pain in the butt. And the switch is out as far as it goes.
Old 12-29-2011, 11:19 PM   #4 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Your welcome.
Some clutch pedals have a pad on the safety switch contact surface. If there was, and its missing, that could explain why the switch is not being depressed.
