Rear Passenger Window problems - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 2nd Generation (1990-1995)
2nd Generation (1990-1995) Discussion area for the second generation Toyota 4Runner.
Old 01-04-2012, 10:49 AM   #1 (permalink)
View fitzi6_7's Photo Gallery
Question Rear Passenger Window problems
My rear passenger window will go down but not up. I replaced the drivers side master switch, the passenger door switch and it will still not go up. What else is it?
Thanks fellas, I live in Oregon where it rains every other hour...
fitzi6_7 is offline   Reply With Quote
Old 01-04-2012, 06:14 PM   #2 (permalink)
out on bail
fourwd1's Avatar
Gameroom cash: $593155
View fourwd1's Photo Gallery
If it works in one direction that means the motor and the wiring are good.
The switches just reverse the polarity of the voltage to the motor to control up or down.
If the window relay was bad none would work.
The master panel has some control circuitry in it, but nothing specific to that particular window.
Right now I can't see why it doesn't work.
Were the replacement switches new or used?
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
Old 01-04-2012, 06:49 PM   #3 (permalink)
They were new.
Old 01-09-2012, 06:09 PM   #4 (permalink)
So I ran wires off my battery directly to the motor wires and viola it worked. Window up, but it didn't fix my problem thinkin I got an issue with my ground somewhere...
