Overdrive issues - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 2nd Generation (1990-1995)
2nd Generation (1990-1995) Discussion area for the second generation Toyota 4Runner.
Old 02-12-2012, 10:17 AM   #1 (permalink)
View dsr4cse's Photo Gallery
Overdrive issues
I have a 1994 4runner and it has a hard time going into overdrive and staying there. I have checked the fluid and my thermostat is not bad. Could it be something as simple as a tranny service with a new filter and a sensor? Or something more complicated? I appreciate all the feed back. I can get than.
Sent from my AT100 using AutoGuide.com App
dsr4cse is offline   Reply With Quote
Old 02-15-2012, 10:11 AM   #2 (permalink)
View alicat's Photo Gallery
2nd Generation overdrive issue
I had the same thing my truck was kicking in and out of overdrive and the light flashing on and off, not sure if this is the same issue you have but i changed the coolant sensor and it fixed my problem, the light still flashes but i think that is a computer issue, but no more overdrive issues, i also changed the thermostat at the same time(toyota one)even though it did not need it was recommended to do it...hope this helps....simple 50.00 fix
alicat is offline   Reply With Quote
Old 02-15-2012, 07:15 PM   #3 (permalink)
out on bail
fourwd1's Avatar
Gameroom cash: $593155
View fourwd1's Photo Gallery
Another possibility is a failing O/D solenoid.
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
Old 02-15-2012, 09:36 PM   #4 (permalink)
I am sending it to my mechanic and he is gonna service the tranny and also change the overdrive sensor,changing my oil,thermostat,throttle control sensor,and do a complete tune up on it. I hope that fixes it. I know it a little extreme but it prob needs al that anyway. Thanx for the advice.
