Emergency Turn Signal Flasher Location - Toyota Nation Forum : Toyota Car and Truck Forums
2nd Generation (1990-1995) Discussion area for the second generation Toyota 4Runner.
post #1 of 2 Old 11-20-2013, 02:00 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Hi and thanks for your intrest.
I have 1991 Toyota 4x4 pickup with extended cab; 3.0 L V6 engine. I would like to know where to locate the Emergency/ Turn Signal Light Flasher unit. Where is the flasher located. According to the auto parts store the flasher operates both the emergency lights and turn signal.
PS: Problem I am having is when I turn on headlights the turn indicator on right side stays lit. When I use the turn signal for a right turn (with headlights on) the tail lights and license plate lights flash on and off with the turn signal on the right front.
Thanks-- Mike
WaveRunnerMN is offline
post #2 of 2 Old 11-26-2013, 09:26 PM
Soylent Green sales
fourwd1's Avatar
Quoted: 196 Post(s)
In this case, the parts store is correct.
One flasher unit works both systems, but there are separate fuses for each. So if either works the flasher is good.
It's located above the fuse panel behind the drivers kick panel. Usually its a green, looks like a relay.
As for your problem, i'd suspect wiring, especially if you have added trailer light wiring.
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 2nd Generation (1990-1995)
User Tag List
Linear Mode Linear Mode
Back
