2002 4runner radiator/head gasket issues
Have a 2002 4runner SR5 Sport with about 175K miles. Looking for advice -
In Dec. started spewing foam - was told transmission cooler ruptured into radiator mixing antifreeze/transmission fluid. Replaced radiator, flushed transmission and coolant. Eventually replaced hoses. 7 months later started overheating and losing antifreeze. Dealer says original failure gummed up engine block, causing lack of coolant, head gasket failure etc, never mind that it happened a day after dealer serviced it.
Basically says transmission is questionable, although it's gone 7 months no issues, and head gasket need to be replaced at a minimum + probably other engine damage. Looking for feedback on whether it's worth trying to salvage. Otherwise it's in decent shape for 175K miles.
The original problems seems like a pretty horrible design flaw, interested to know if anyone else ran into this, or thoughts on why it might happen other than just bad luck - the vehicle has been serviced like clockwork...
