4Runner Surf - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 3rd Generation (1996-2002)
3rd Generation (1996-2002) Discussion area for the third generation Toyota 4Runner.
Old 07-26-2010, 02:03 PM   #1 (permalink)
View gsyonge's Photo Gallery
Hi, I've scanned a 4 runner surf, equipped with a VE DENSO electronic diesel fuel pump. The result was a CODE 14 (ignition coil): this is a diesel engine, any ideas what the problems might be?.
Thanks in advance,
Gus (from southern Chile)
gsyonge is offline   Reply With Quote
Old 07-27-2010, 11:17 AM   #2 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3638550
What are the symptoms leading up to you reading error code 14?
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is offline   Reply With Quote
Old 07-27-2010, 02:19 PM   #3 (permalink)
Thanks for your message. The main symptom is that running at 2000 r.p.m. it looses power and blue/grey smoke comes from the exhaust pipe. Before and after 2000 r.p.m. the engine runs OK and no smoke from the exhaust.
Thanks, Gus
Old 07-27-2010, 08:42 PM   #4 (permalink)
Do you feel lucky?
TrailDust's Avatar
The blue smoke indicates you're burning oil, but there could be more than one cause. I'd suspect either piston rings or valve stem seals. That's where I'd start.
2002 Avalon XL
