Skid plate bolts - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 3rd Generation (1996-2002)
3rd Generation (1996-2002) Discussion area for the third generation Toyota 4Runner.
Old 09-21-2010, 07:31 PM   #1 (permalink)
#2!
Gameroom cash: $102228
View #2!'s Photo Gallery
Skid plate bolts
The threads on the bolts to my skid plate are rusty and disappearing. I think I have 4-5 left holding up that will still thread through. I want to get the skid plate on tight to see if its what's causing a rattle.
What do I get to replace them?
#2! is offline   Reply With Quote
Old 09-21-2010, 09:44 PM   #2 (permalink)
Gameroom cash: $207700
View kball's Photo Gallery
Hmm... I think the nuts are welded in place are they not? Can you tap them a size bigger and get new bolts?
kball is offline   Reply With Quote
Old 09-21-2010, 10:39 PM   #3 (permalink)
#2!
The nuts are welded in place but I'm thinking the threads in those are fine.
Every time I take the skid plate off I end up throwing away a bolt because the threads have rusted away and it wont snug up.
I was wondering if anyone knew of a good replacement for those bolts. Type & size. Or if I should just go hit up the dealership for some.
Old 09-21-2010, 10:54 PM   #4 (permalink)
Sorry I misread the original post. Yep I had a stripped bolt on mine when I first bought it. I found a bolt in my tool box that was the same size and metric thread and forced it in to tap the threads. Sorry though I'm not sure of the metric size. I'd just take one of the old good ones and match it up. Make sure to get one that's high strength steel.
The Following User Says Thank You to kball For This Useful Post:
#2! (09-21-2010)
Old 09-22-2010, 12:13 AM   #5 (permalink)
Every road's a playground
toyotaholic's Avatar
View toyotaholic's Photo Gallery
try a lock washer
they're available at auto parts stores.
toyotaholic is offline   Reply With Quote
Old 09-22-2010, 05:00 AM   #6 (permalink)
Gameroom cash: $425365
View jetwhine's Photo Gallery
#2,
When you get new bolts use some anti sieze on the threads so they won't rust. And use the lock washers as stated by toyotahalic, and you might need one size longer to accept the lock washer.
jetwhine is offline   Reply With Quote
Old 10-28-2010, 02:22 PM   #7 (permalink)
View chuckoff's Photo Gallery
Size is 8mm x 1.25 (pitch) x about 32 mm long.
chuckoff is offline   Reply With Quote
The Following User Says Thank You to chuckoff For This Useful Post:
#2! (10-28-2010)
Old 10-28-2010, 04:59 PM   #8 (permalink)
#2!
Originally Posted by chuckoff View Post
Size is 12mm x 1.25 (pitch) x about 32 mm long.
Perfect! I'll go pick some up.
Old 10-28-2010, 05:39 PM   #9 (permalink)
Wait, sorry, I meant 8mm. 12mm is the hex size-wrench size.
Old 10-28-2010, 06:03 PM   #10 (permalink)
chuckoff,
You could just tape the hole to the next common size if none of the other ideas work.
Old 11-01-2010, 07:24 AM   #11 (permalink)
Originally Posted by jetwhine View Post
chuckoff,
Not my vehicle.., There may not be enough material thickness in the weld nuts to go oversize.
Old 11-01-2010, 08:06 AM   #12 (permalink)
chuckoff.
Think outside the box, You can relocate them. Tape the frame.
