replacing timing belt - help - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 3rd Generation (1996-2002)
3rd Generation (1996-2002) Discussion area for the third generation Toyota 4Runner.
Old 10-23-2010, 06:36 PM   #1 (permalink)
View keanha's Photo Gallery
Anyone know how to compress that timing belt tensioner without having to remove your A/C so you can get the bolts to physically remove the tensioner?
keanha is offline   Reply With Quote
Old 10-24-2010, 07:23 AM   #2 (permalink)
No More Turbos!
View Pwner Guy's Photo Gallery
Unbolt your A/C compressor and move it to the side, if you want use some mechanics wire to hang it from the frame. You don't have to disconnect the lines, just move the compressor. Also have a small pin and a vice handy to compress the belt tensioner and keep it in place until you need it after you get it off.
Richard Hammond - You can stick a BMW badge on a dead cat... And people would still buy it.
Pwner Guy is offline   Reply With Quote
Old 10-28-2010, 02:14 PM   #3 (permalink)
View chuckoff's Photo Gallery
You can get to the inner bolt without removing the compressor using a 1/4" dr. wobble extension adapted to 3/8' for a breaker bar. You first have to lower the wire harness that goes under the front crank pulley and then there is just barely enough room to get the tool in there to get the bolt out. It is a tight squeeze, but I work on that stuff for a living and have never loosened, or removed the compressor to do the job.
chuckoff is offline   Reply With Quote
