Originally Posted by jetwhine
dansew,
I'm glad that you fixed your problem. May you have many more miles of trouble free driving.
Well, the update of it is that the problem has continued since my last post, I removed the left rear brake drum, and there is a slight axle seal leak, which was enough to cause the oily brake shoes to stick.
Information from old posts on this forum, has educated me to the fact that there is a breather for the differential located on top of the left axle housing, and if it gets stopped up, pressure from friction heat in the differential will cause lubricant to be forced out the axle seals.
I cleared the breather, cleaned off the brake linings, and the symptoms are getting better as I drive, still sticky, but seems to not be quite as bad.
I hope this will solve the problem, because replacing all the seals and bearing on just one side was quoted anywhere from 900 to 1200 dollars.
The photos in the other post showed lubricant splattered all over the inside of the tire, evidently my leak was not that severe, because there is no outward sign of a leak.
One other thing, I couldn't find any mention of that breather in the shop manual.
