I have been battling this for three weeks with little help from other forums.
First off, my truck is a 97 T4R Limited w/ 4wd button.
I can engage 4wd (4H and 4L) instantly using the button, however, I can not disengage 4wd to go into 2wd unless I switch the vacuum lines on the VSV or turn the truck off.
So far, I have:
* Visually checked all the vacuum lines.
* Removed and checked the neutral position switch, 4L position switch and 4wd sensor on the transfer case.
* Checked the TC actuator using an ohm meter. 185ohms. I tried to check #2/#3 and the body, but I couldnt get a reading.
* Replaced the ADD switch on the front diff.
* Hot wired the VSVs and they click.
* Hot wired the actuator on the TC and it moves back and forth.
Also, my propeller turns in 2wd.
Thanks in advance
