grinding/whining noise when shifting - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 3rd Generation (1996-2002)
3rd Generation (1996-2002) Discussion area for the third generation Toyota 4Runner.
Old 01-02-2011, 07:34 PM   #1 (permalink)
View ethanjscott's Photo Gallery
I have a 96 4unner v6, 4wd, 280,000 miles. i recently took a 1500 mile road trip through the desert and in to the mountains where I had to put some pretty good time in 4wd. Got back home and found that when I shift, occasionally a whining or grinding noise comes out when i press the clutch in. however, the minute i depress the clutch the noise stops. It goes into gear fine, and still drives like a champ when in gear. If it didnt make a noise, i wouldnt know there was a problem at all. The noise is also inconsistent, usually only happens after the car is warm. I'm a far cry from a mechanic, just trying to gauge how much it'll cost me and the likely cause of the noise. HELP!
ethanjscott is offline   Reply With Quote
Old 01-03-2011, 06:11 AM   #2 (permalink)
Gameroom cash: $425365
View jetwhine's Photo Gallery
ethanjscott,
Sounds like you might have a throw out bearing starting to go out on you.
jetwhine is offline   Reply With Quote
Old 01-03-2011, 01:16 PM   #3 (permalink)
throw bearing
Thanks for the reply. Curious, the throw out bearing sits between the transmission and the clutch? Hence if it was going it 'd cause friction between any play between the two? Any idea how much it'd cost to replace it? is it labor intensive?
Thanks again.
Old 01-04-2011, 01:43 AM   #4 (permalink)
ethnajscott,
I would suspect what you are hearing is the infomous bearing noise. The bearing itself wearing out. Friction possibly.
Every local is different but I would put it in the $500-$700 range. If someone else can give a better idea great!
This is just a guess. Labor intensive: to me yes.
