rough engine performance
I recently purchased a used 2000 4runner limited with 4w driveand about 193k miles on it. The check engine light comes on and goes off periodicaly. The code was P0305 (misfire cylinder 5). It idles rough and accelerates poorly. It shakes violently and a big power loss is noticable. I have replaced all spark plugs and wires. I also replaced the coil pack that is associated with cylinder 5. This had no effect. Today I cleaned the mass air flow sensor and the throttle body. When I started it, the check engine light was still on, it idled high but ran without vibration or poor acceleration for at least 30 miles. I thought the problem was fixed and decided to clear the code with a code reader. It then started to run poorly again. Now the codes are for P0305 (cylinder 5 misfire) and P0171 (running lean). Please help.
Thanks for your time.
