P0130*3 o2 sensor...grr. - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 3rd Generation (1996-2002)
3rd Generation (1996-2002) Discussion area for the third generation Toyota 4Runner.
Old 01-21-2011, 06:21 PM   #1 (permalink)
View Nails's Photo Gallery
3rd Generation P0130*3 o2 sensor...grr.
I recently bought a 2000 4runner which has been pretty awesome but the other day the CEL came on. I took it to Autozone and they hooked up a sensor which came back with a P0130 and a P0133. The tech said it was the bank 1 sensor 1 o2 sensor and recommended replacing it. I got the part...the problem is I can't seem to find it to replace it. The tech said it was on the drivers side but the 2 sensors I can find are on the passengers side along the exhaust pipe...help?
2000 4runner v6 automatic 4x4 SR5 Federal exhaust
Nails is offline   Reply With Quote
Old 01-22-2011, 03:08 AM   #2 (permalink)
Gameroom cash: $425365
View jetwhine's Photo Gallery
Nails,
Bank 1 sensor 1 should be your forward sensor on your exhaust pipe. The book shows it on the drivers side but if yours is on the passenger side change the fwd one.
jetwhine is offline   Reply With Quote
Old 01-27-2011, 11:30 PM   #3 (permalink)
Thanks for the reply jet!
The part that they sold me wouldn't fit in the first bank but there is another further down the exhaust (approximately under the passenger side second seat) that was pretty trashed so I just swapped it out with the one I got. The tech made it seem like there are four o2 sensors on the vehicle but I can only find the two...am I missing something?
Old 01-28-2011, 12:00 AM   #4 (permalink)
Nails,
Not that I'm aware of. But you still need to change the front one.
I also forgot to mention that the only sensor to buy would be a denso OEM. They are the most reliable. They cost just a little bit more but worth the money. Don't get the universal one they are not worth the time or money. On those you need to cut wires and I would rather just hook up a connector. Plus the connector is OEM. Stay away from cutting.
Old 01-28-2011, 11:27 AM   #5 (permalink)
Do you have a part number or anything for the front sensor? I'm going to have to order it and I want to make sure I order the right part.
Old 01-29-2011, 12:24 AM   #6 (permalink)
Nails,
On Rock auto http://www.rockauto.com/catalog/raframecatalog.php. The part number for the upstream Denso OEM is 2344161. The cost is $65.79 U.S. Hope this helps.
Old 01-29-2011, 08:39 AM   #7 (permalink)
Toyota-Lexus Fanatic
mandyfig's Avatar
View mandyfig's Photo Gallery
Ebay sells OEM Denso O2 sensors, too. Need actual part numbers, though.
04 SC430 05 RX330
96 Camry LE T-boned Oct. 09 RIP
mandyfig is offline   Reply With Quote
