overheating - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 3rd Generation (1996-2002)
3rd Generation (1996-2002) Discussion area for the third generation Toyota 4Runner.
Old 02-05-2011, 10:23 AM   #1 (permalink)
View wolfus's Photo Gallery
USA overheating
I have a 1999 4runner 4wd 6 cyl that overheats sometimes. Could it be the thermostat getting stuck sometimes that would cause this? I bought a new thermostat but I am not sure of the CORRECT way to drain the radiator . I dont want to take off the nuts from the studs and have anti-freeze leak all over the place.
wolfus is offline   Reply With Quote
Old 02-05-2011, 11:55 AM   #2 (permalink)
Gameroom cash: $207700
View kball's Photo Gallery
Is your coolant level okay? How does it look? There's a drain at the bottom of the radiator. Thermostat can stick.
kball is offline   Reply With Quote
Old 02-05-2011, 11:57 AM   #3 (permalink)
the level is good thanks and the color is grn like af
Old 02-06-2011, 12:45 AM   #4 (permalink)
Gameroom cash: $425365
View jetwhine's Photo Gallery
wolfus,
Since you have the standard anti freeze in it I would drain it and put some Toyota fluid in it. . It has better properties for the Aluminum engine components. The Toyota coolant is Red in color. It is much more expensive but worth it in the long run. And yes also agree on the sticking. You might also put the new T-stat in a pan of water and heat it up to make sure it opens when hot. Just a precaution so you don't have to trouble shoot a bad from new T-stat. I have seen them bad new and it causes problems when trying to figure out why a rig is still overheating after T-stat change. Hope this helps.
jetwhine is offline   Reply With Quote
Old 02-10-2011, 10:23 PM   #5 (permalink)
View MattInLA's Photo Gallery
Teh things
That can cause overheating
CLOGGED RADIATOR - LEAKING CAP - BAD THERMAL SENSOR - BAD FAN SWITCH - BAD FAN - BAD FAN CLUTCH - LOOSE FANBELT - BAD THERMOSTATIC VALVE - HEAD GASKET FAILURE - CLOGGED ENGINE PASSAGES... I'm sure there's more.....
MattInLA is offline   Reply With Quote
Old 02-11-2011, 06:43 AM   #6 (permalink)
The only problem I have with the Clogged Radiator, Leaky Radiator cap, Bad Fan, Bad Fan Clutch, Loose Belt, Head Gasket failure, Clogged Engine Passages is that it would overheat all the time. It is an intermittent problem which I would suspect the T-stat first. Now the only thing I did not mention is that if the rig does not act/sound like it is overheating then I would suspect an indication problem.
