If It's running very hot I'd say it's running lean, not rich.
have you checked your fuel pressure? replaced the fuel filter? checked the pressure regulator? clogged injectors?
If you really think you've got raw fuel going into the exhaust, you'll need to know which cylinders aren't firing because that is the only that you're going to end up with that situation. If that was the case, I'd check my plugs, wires, coil packs, and other ignition componants.
I hope that give's you a good starting point.
"Fools", said I, "You do not know, silence like a cancer grows.
Hear my words that I might teach you. Take my arms that I might reach you"
But my words, like silent raindrops fell, and echoed, in the wells of silence.....
Jason Johnston
Toyota/Scion of Des Moines
(800)342-7045
