How many miles on your cat?
Factory cats last about a 100000 miles as a rule of thumb, but like chuckoff said, other things can cause a 420 code.
The computer compares the front o2 sensor output with the rear o2 sensor output , if the outputs are the same, the computer will throw that code. They should be different. With a good working cat there will be less oxygen at the rear o2 sensor and the signal will have a lower frequency.
Air leaks in the exhaust ahead of the o2 sensors can also cause this, sometime an overly sensitive computer too.
If you have a analog multimeter( with needle) or a digital meter you can backprobe your sensors and time the crosscounts( thats really what the computer is looking at). Crosscounts are the points at which the signal goes from low to high and high to low( think of a sine wave). The service manual will show how to check this.
If you already do your own work on the truck,its not that hard to change the cat. Factory cats are very expensive( they are the best) but you can get an aftermarket one for much cheaper.
If you have a bad cat, be sure you fix any major coolant burning or oil burning problems before you replace it, because it will ruin the new cat and or o2 sensors. Oil burning will take a while , but coolant will damage them in a few miles.
