98 runner clutch not disingaging - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 3rd Generation (1996-2002)
3rd Generation (1996-2002) Discussion area for the third generation Toyota 4Runner.
Old 05-26-2011, 07:25 PM   #1 (permalink)
View 4RunnerRuck's Photo Gallery
Hi Guys and Gals. I have a 98 4 Runner Sr5 5 speed. Today while going to work I went to push the clutch pedal down and it stuck down and the clutch did not disingage. I had to pry the clutch pedal up with my feet and restart it. It did it to me about 6 times. It seems to do it more when running and in gear then not running. Anyone have any ideas what could be the problem? Or if anyone else has had the problem? Thanks Guys. Look forward to what ya all have to say. Peter
4RunnerRuck is offline   Reply With Quote
Old 05-27-2011, 09:10 AM   #2 (permalink)
Let me out of my cage....
HATEnFATE's Avatar
Gameroom cash: $163450
View HATEnFATE's Photo Gallery
Could be a number of things.
Bad pressure plate.("groves in the fingers")
Bad Throwout bearing
Sticking Master cylinder
Sticking Slave cylinder
Air in the Clutch lines.
How many miles are on this clutch?
"Fools", said I, "You do not know, silence like a cancer grows.
Hear my words that I might teach you. Take my arms that I might reach you"
But my words, like silent raindrops fell, and echoed, in the wells of silence.....
Jason Johnston
Toyota/Scion of Des Moines
(800)342-7045
HATEnFATE is offline   Reply With Quote
Old 05-28-2011, 02:55 AM   #3 (permalink)
Gameroom cash: $425365
View jetwhine's Photo Gallery
4RunnerRuck,
Did you check for worn parts at the clutch pedal itself? Maybe a bad bushing or broken pedal arm?
jetwhine is offline   Reply With Quote
Old 05-28-2011, 10:45 AM   #4 (permalink)
30YRTOYOTAPARTSEXPERINCE
TOYOPARTSMAN's Avatar
Gameroom cash: $327600
iTrader Score: 12 reviews
View TOYOPARTSMAN's Photo Gallery
hard to tell without further inspection, but I would start by eliminating the obvious, as one member said, the blue bushings on the pedal, check and see if you're leaking brake fluid inside the cab by the pedal, then check the master to see if it has fluid in it and work your way down.
An all of a sudden situation prompts me to think Master or Slave cylinder, but again, hard to tell without inspecting it.
Gary Smith-Parts Manager
garys@toyotaofnewnan.com
www.ToyotaofNewnan.com
678-854-9601
TOYOPARTSMAN is offline   Reply With Quote
Old 07-15-2011, 01:27 PM   #5 (permalink)
View chuckoff's Photo Gallery
Clutch pedal mechanics, clutch master cylinder, or clutch slave cylinder all can fail.
Is the clutch master cylinder full?
chuckoff is offline   Reply With Quote
Old 07-16-2011, 01:26 AM   #6 (permalink)
4RunnerRuck,
Also check for a cracked clutch/brake pedal bracket.
