02 ckengine, brake, abs, vsc trac indicators on
Just joined to ask about my son's 4Runner, though I've gotten much great info in the past from the toyotanation for our 02 Sienna.
His 4Runner is a 2002, 2 wheel drive, auto trans. It has the check engine, brake, abs, vsc trac, & vsc off indicators on solid. He said that his transmission also seemed to not be shifting right. Here's what we did so far:
1. Checked his auto trans oil with engine idling. Oil was extremely low, with the level ony about 1/4" up on the tip of the dip stick. He said he never checked the oil since he bought the 4Runner about 3 years ago. Couldn't believe it!. --- Added about 1.5 quarts of Dextron III oil to bring the level to full and he said there was a huge difference. But one time when an auto shift occurred, there was a momentary slipping and then the shift was OK.
2. Hooked up an OBD-II scanner and got a "P0500 01/03" code. The P0500 is a speed sensor error but I don't know what the 01/03 means.
3. Ohmed all 4 wheel speed sensors and the ohm readings were: LF=1720 ohms, RF=1749 ohms, LR=1418 ohms, RR=1381 ohms. Ohmed the auto trans speed sensor and it read 672 ohms.
4. Hooked up an oscilloscope to all 5 sensors, by disconnecting the connectors. So the o-scope was connected open circuit to each sensor. Every sensor showed wave patterns with no apparent missing pulses. The peak-to-peak readings were:
LF=.15 volts spinning tire by hand.
RF=.1 volts spinning tire by hand.
LR= .4 volts with both tires off ground and trans in drive.
RR= .33 volts with both tires off gnd and trans in drive.
Autotrans=.22 volts with both tires off gnd and trans in drive.
As I mentioned, every sensor showed wave patterns with no apparent missing pulses. So would it be safe to say that all 4 wheel speed sensors and the auto trans speed sensor are all good? And that the rings that the sensors are monitoring are all good too?
If all of the above is good, what's our next step?
Thanks,
Raptor88
