I am thinking this might be what has happened.My son has been driving the 97 forerunner and the other day he called me and said it was blowing white smoke,so he drove it back home and parked it(1/2 mile or so). He said it was missing a little too.
So when I went to check it out,coolant resevoir was empty,but radiator still had fluid in it.Oil is golden and not frothy at all.(this part throws me...)My son stated it never overheated while he was driving it,fwiw.
I tried to start the engine,but it acts like a dead battery,even though it's not.It's almost like it's frozen. It tries to turn then all dash lights go dim to dead,until I try again.Don't want to fry the starter.A neighbor stated a cylinder could be full of coolant causing it to act similar to frozen.
At this point,I need advice....
This engine has 135k on it.What steps should I take to diagnose if it is a head gasket and which one? What other potential problems might I run into that would add to the repair cost? Is this common for these v-6's,or unusual?
I have found a used engine for 1,250 with 67k miles on it. Do you think I would be better off just swapping that one out? It would probably need timing belt,water pump,etc. I can see it running about $2k if I go this route,but it is an option.
What are the down sides of just replacing the head gasket,if that is what it is?
I am concerned about longevity,with coolant in the cylinder(s) and all,even though the oil looks pristine.
What sort of advise would anyone with lots of knowledge on these engines give me?
TIA. First post BTW!
