bottoming out! - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 3rd Generation (1996-2002)
3rd Generation (1996-2002) Discussion area for the third generation Toyota 4Runner.
Old 07-18-2011, 03:21 PM   #1 (permalink)
View JWOD's Photo Gallery
3rd Generation bottoming out!
I have A 2000 limited 4-runner with 232000K on it & brand new shocks on the rear and it bottoms out on relatively small bumps , I noticed that the bump stop is only 2" approx. away from the axle. I also owned a 96 4-runner SR5 with more KMS on it & it sat a little higher and did not bottom out.....is there 2 different types of springs in regards to height & stiffness?
JWOD is offline   Reply With Quote
Old 07-18-2011, 09:16 PM   #2 (permalink)
out on bail
fourwd1's Avatar
Gameroom cash: $593155
View fourwd1's Photo Gallery
It's quite possible the spring rate could vary by year and model. The LTD could have a softer rate for a better ride, which could make it fatigue sooner.
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
Old 07-19-2011, 07:46 AM   #3 (permalink)
Gameroom cash: $207700
View kball's Photo Gallery
96-98 had pretty similar height coils. Some 99-00's got the highest stock coils. Then the firestone SUV rollover thing happened and so the 01-02 got the lowest coils.
It's common for the coils to sag with age which I'm sure is why you are bottoming out. Replace the springs with stock coils or for a small lift go with 99 coils.
There's a pic on the net somewhere that showed all the years of coils together but I couldn't find it. Here's one that shows some of them.
http://www.sonoransteel.com/includes...ront_coils.pdf
kball is offline   Reply With Quote
Old 07-19-2011, 10:50 PM   #4 (permalink)
out on bail
fourwd1's Avatar
Are you talking about the spring rate of the coils or the actual "unloaded" height measurement of the coils ?
89 4Runner - stock
Old 07-20-2011, 08:08 AM   #5 (permalink)
I'm talking about the unloaded ride height and as you can see from the link in my previous post the actual coil height is different. I don't know if they changed the payload capacity of the 3rd gens over the years or not.
Old 08-12-2011, 05:15 PM   #6 (permalink)
View changedsoul's Photo Gallery
I t=think I have a similar issue only Mine is a 2000 4Runner with 160K Miles, and my spring dampening thing inside the actual coil spring is only about 1" to 1.5" from the axle. I dont notice it bottom out much unless I go over speed bumps or there are larger than normal bumps in road. Not speed bumps as in launching over them, but just the simple slow moving over them when the rear goes up and then back down, it bottoms out.
What would be typical height? The truck itself doesnt look to be sagging, but then again 1" higher might make a huge ride difference but not look all that different.
Is there a spec for where it should be riding with no load? So I can know if this is normal, or if I need to replace the springs?
changedsoul is offline   Reply With Quote
Old 08-24-2011, 07:48 PM   #7 (permalink)
View dee44's Photo Gallery
Canada
Just a thought.
Check the body mounts.
I thought my 98 was bottoming out but it turned out to be one of the body mounts just in front of the rear axle.
Also a very inexpensive way to improve ride hieght that I used because I tow a boat is air bags in the springs. Mine are made by Firestone and cost about $80. had them for a year no problems.
http://www.suspensionconnection.com/...con/4135T.html
dee 44
2010 Camry SE 6spd Manual
98 4Runner V6 4X4
dee44 is offline   Reply With Quote
