1. Does the window work in both directions using the pass side switch?
3. Switches don't usually fail in the ON position, but you could try this to find out
a. disassemble the panel to access the switch
b. disconnect the electrical connector on the back of the switch
If the AC goes OFF then the switch is shorted in the ON position.
If the AC remains ON the problem is elsewhere.
Plus, if it is the switch, you are halfway done replacing it.
Also, does the AC shut off if the Fan switch is placed in the OFF position?
 SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
