Nightmare BIG TIME!! - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 3rd Generation (1996-2002)
3rd Generation (1996-2002) Discussion area for the third generation Toyota 4Runner.
Old 09-02-2011, 07:33 PM   #1 (permalink)
Big Dan BEng
Germanguy's Avatar
View Germanguy's Photo Gallery
Evening all.
I have an intermitant problem.Engine hot or cold,the engine will start missfiring bad,its cutting on cyl 4.
I have a code #P0304 but NO engine light comes on.
To stop this shaking I have to stop and restart engine and then problem goes away.
Wiring,plugs are new.ECM good.
Its a 3.4ltr V6
Engine code is 5VZ-FE
Could engine coolant temp sensor or #4 injector be the culprit??
Cheers
Big Dan
In my stable I have....
1976 280 SE,1983 300SDL,1992 190D,1995 S 600 V12,
1980 Unimog Expedition and a 2009 Unimog U 5000.
Cairns Australia
Vancouver Canada
http://allformercedesbenz.blogspot.com/
Germanguy is offline   Reply With Quote
Old 09-03-2011, 01:47 AM   #2 (permalink)
Gameroom cash: $425365
View jetwhine's Photo Gallery
Germanguy,
The first thing I would do is replace the #4 cylinder sparkplug. Then if it still misses then I would look at the firing circuit and then check the injector/replace. The ECT would effect all cylinders as far as I'm concerend. If you replace the sparkplug make sure you use only Denao or NGK, nothing else. No substitutes!
jetwhine is offline   Reply With Quote
The Following User Says Thank You to jetwhine For This Useful Post:
Germanguy (09-03-2011)
Old 09-03-2011, 10:42 AM   #3 (permalink)
Big Dan BEng
Germanguy's Avatar
I will do that this afternoon.
It might take a day or so for the problem to appear! Hope it doesn't!!
I will keep you all posted.
Cheers
Big Dan
Cairns Australia
Vancouver Canada
