1999 4Runner Parts Wanted - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 3rd Generation (1996-2002)
3rd Generation (1996-2002) Discussion area for the third generation Toyota 4Runner.
Old 09-12-2011, 03:29 AM   #1 (permalink)
XPY
XPY's Avatar
View XPY's Photo Gallery
Canada 1999 4Runner Parts Wanted
Just because I'm anal about my 4Runner. Does anyone have or know where I can get:
a FL black plastic cover for the running board (driver side front)
a RR black plastic cover for the running board (passenger side back)
Driver side seat FL beige plastic floor bolt cover (if your seated it's on the left side)
And that stupid back seat pull out cup holder in the center console
Prfer used not looking to spend a lot FREE is good!
THANKS
XPY is offline   Reply With Quote
Old 09-12-2011, 08:19 PM   #2 (permalink)
Gameroom cash: $425365
View jetwhine's Photo Gallery
XPY,
Have you tried the Junkyard, Craigslist, Ebay?
jetwhine is offline   Reply With Quote
Old 09-13-2011, 08:24 PM   #3 (permalink)
out on bail
fourwd1's Avatar
Gameroom cash: $593155
View fourwd1's Photo Gallery
Have you posted in the Parts Wanted forum?
That's where this really belongs.
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
Old 09-13-2011, 09:31 PM   #4 (permalink)
XPY
XPY's Avatar
Had trouble finding that parts wanted forum but I found it.
Old 11-17-2011, 10:01 AM   #5 (permalink)
View Runner Rider's Photo Gallery
i took the running boards off of my 90 gen 2 4runner and they have been sitting in my barn for about 10 years now. if you do some research and see if they will fit i will go take a look at them to see if they are any good, only problem is i live in louisiana and i see you have a canadian flag. if you live in canada the shipping is going to be pretty killer
Runner Rider is offline   Reply With Quote
Old 11-17-2011, 03:54 PM   #6 (permalink)
XPY
XPY's Avatar
Thanks, my actual boards are fine it's the plastic end caps that are cracked.
Old 11-29-2011, 07:15 AM   #7 (permalink)
well sorry man i dont think i can help you there
Old 12-04-2011, 04:38 PM   #8 (permalink)
View engine1CD's Photo Gallery
Search for this cat.numbers
1.cup holder on console 55620-35050
2.floor bolt cover is 72138-35020-B0(E0) depend on interior trim code.
3.FL plastic cover is 55606-35010 or 5560-60010 dep. of date and trim code.
4.RR black plastic cover for the running board (passenger side back ???? Where is located...
engine1CD is offline   Reply With Quote
Old 12-04-2011, 04:51 PM   #9 (permalink)
XPY
XPY's Avatar
Canada
trim code is based on what color? (Beige) is it located on door panel?
same with trim code?
The factory running boards have two black plastic end covers on them, the back one on the passenger side.
Oh! And where should I be searching?
Old 12-06-2011, 01:15 AM   #10 (permalink)
XPy
There is a label on front left door, on outer pillar, black label with all info about your vehicle, VIN, trim code, Color code, model name. you need to check your trim code.
Trim code color is not same with your vehicle color code. they are different. When you can search for parts in dealership, you need your vin, and on one vin can be different trim codes depending on level of equipment of your vehicle.
Old 12-06-2011, 12:46 PM   #11 (permalink)
XPY
XPY's Avatar
OK Thanks,
I do know that but won't pretend to know everything about what those codes stand for.
So mine is actually:
C/TM 1C0 / FB45
If it helps anyone else:
How to read door labels:
1992 or newer;
http://www.toyconnection4x4.com/code...92-4runner.jpg
1991 or older;
www.toyconnection4x4.com/code_label.html
Old 12-07-2011, 05:00 AM   #12 (permalink)
1C0 is color of your vehicle, FB45 is your trim code.
Old 12-07-2011, 05:23 AM   #13 (permalink)
Can you make a picture, of part you wanted I cant find it in catalog, with your explanation. Thanks.
Old 12-07-2011, 09:32 AM   #14 (permalink)
XPY
XPY's Avatar
System won't let me post photos (attachments)
Anyways the "RR black plastic cover for the running board";
Their are 2 black plastic end covers on each factory running board, 1 on the front & 1 on the back. My front left (FL drivers’ side) one is cracked & my right rear (RR passenger side) one is cracked.
Just figured most guys that bend their running boards just need a new board not the end caps so thought their might be a few kicking around. Guess not?
If you need a better description of the other parts let me know, when you describe stuff yourself it seems obvious, but I do know better.
