Timing Belt Replacement/Radiator Questions
Hi; I have a '99 4Runner (2WD 4-Cyl) with about 180K miles. I have not had the timing belt replaced; when I called yesterday to get a quote from a mechanic with great reviews, I was told they have timing CHAINS that don't need to be replaced unless they fail-the same with the water pump. Is this accurate?
It has started squealing when I turn it on, so I'm assuming this is an AC belt? Twice I have turned it on (only when it was hotter over the summer) after having it off for a few minutes while running into a store to get something, or pumping gas, it won't start. Power is fine, but engine does not turn. After waiting for 20-25 minutes, starts up without a problem. Could this be radiator related, as I have heard a hissing sound from under the hood while waiting for the 20-25 minutes to pass?
