Cracked block at Oil pressure switch - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 3rd Generation (1996-2002)
3rd Generation (1996-2002) Discussion area for the third generation Toyota 4Runner.
Old 10-12-2011, 09:47 AM   #1 (permalink)
View Jetmx's Photo Gallery
When I changed my oil filter I noticed that the top electrical part of the oill pressure switch (next to oil filter) was broken off. I bought a new one & started to change it. I got the old one off ok but when I installed the new one, it wouldnt tighten up. When I started the engine, it leaked. Upon close inspection, I noticed a 1 inch crack in the block running down the thread area. I checked around & found out there is no easy fix. It cant be welded because the block is cast. The only permanent fix is replacing the block. I need to use it so I tried using 2 part epoxy around the area & it reduced the leak to a couple of drops when running. Does anyone have any ideas what I should do short of replacing the engine? Is there any permanent epoxy fixes? The several thousand dollars quoted to replace the block may not offset the value of the vehicle. Its a 1999 4runner limited 4x4 v6 with 210k miles.
Jetmx is offline   Reply With Quote
Old 10-12-2011, 09:16 PM   #2 (permalink)
Gameroom cash: $425365
View jetwhine's Photo Gallery
Jetmx,
You could try some JB weld. It might hold it for awhile.
jetwhine is offline   Reply With Quote
The Following User Says Thank You to jetwhine For This Useful Post:
Jetmx (10-13-2011)
Old 10-13-2011, 03:44 PM   #3 (permalink)
Thanks for the advice. I will look into that. There is also a product called Goop that says on the box that you can use it on engine blocks. We'll see!
Old 10-22-2011, 07:54 PM   #4 (permalink)
TACO_KID's Avatar
Gameroom cash: $436515
View TACO_KID's Photo Gallery
it is "cast" but that doesnt mean it cant be welded. its not not cheap alumnim casting. a good TIG guy can fix it. some pics would be useful.
grinding a V in the crack and then TIG should "fix" it. maybe a grinding disc on a dremel. etc. i say TIG might fix it but depends on where that crack goes. a surface weld my crack later if the original crack exerts enough force for expanding/contracting, etc.
my advice, talk to a good TIG guy.
and dont feel so bad, my new 2010 corolla came from factory with a 2" crack in the engine block. engine was rebuilt twice since then.
live a little, step on the gas.
TACO_KID is offline   Reply With Quote
Old 10-25-2011, 08:36 AM   #5 (permalink)
Taco- Thanks for the advice. The welders I talked to said that it would be risky, but I will talk to more TIG welders. I'll try to take a pic
