4WD help - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 3rd Generation (1996-2002)
3rd Generation (1996-2002) Discussion area for the third generation Toyota 4Runner.
Old 12-04-2011, 08:49 AM   #1 (permalink)
View ima4runnergal's Photo Gallery
4WD help
Good morning everyone,
I have an 98 Limited 3.4 4x4. My issue is this... my 4x4 indicator light is on but the 4x4 is not engaged. Any ideas why???
thanks a bunch
ima4runnergal is offline   Reply With Quote
Old 12-04-2011, 04:55 PM   #2 (permalink)
View engine1CD's Photo Gallery
Try to check switch transfer (differential) lock indicator maybe some of wire connectors is rusty, located on below your vehicle on upper left side on your transmission
engine1CD is offline   Reply With Quote
Old 01-27-2012, 11:21 PM   #3 (permalink)
Nothings better!
TheUltimateBohab's Avatar
View TheUltimateBohab's Photo Gallery
are you in 4low? the button doesnt have to be depressed in low.
TheUltimateBohab is offline   Reply With Quote
Old 01-28-2012, 09:28 AM   #4 (permalink)
out on bail
fourwd1's Avatar
Gameroom cash: $593155
View fourwd1's Photo Gallery
The way the system is designed, it's not easy for the 4WD indicator to light without it really being in 4WD.
The front axle has to lock, the t-case has to shift, etc.
Is this in HI and LO ranges? and what makes you think it isn't working?
auto or manual trans?
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
Old 01-29-2012, 04:31 AM   #5 (permalink)
Gameroom cash: $425365
View jetwhine's Photo Gallery
Ima4runnergal,
I agree with fourwd1. The only way I can think that could happen is that the front locker might be broken and engaging to turn the switch on to light the light but broken as far as not engaging the front axle.
jetwhine is offline   Reply With Quote
